RCU Forums - View Single Post - Pull-Pull controls - Bellcrank material question
Old 05-14-2003 | 01:13 PM
CafeenMan
Default Pull-Pull controls - Bellcrank material question
Well, I'm still not convinced. If the pc board can cut through the cable then it can probably cut through a plastic clevis. Fiberglass is very abrasive. I'm thinking either go with plywood or use metal clevises and watch them for wear. What I'd really like to do is hook up directly to the servo horn, but there just isn't room to use a large enough horn.
