ORIGINAL: Skarn
Most use either the flat or v curve throttle curves in idle 1 or 2. It gives you a constant headspeed and the only thing that changes is pitch. Yes, the headspeed will vary slightly as pitch changes, but not too much. And with a straight flat curve of 100, you won't be able to do any better for headspeed!
If this is the best type of curve available 100-100-100 then why dont i just enter that into my transmitter??? seeing as any change in head speed is minimal???
I did use a pitch gauge, what i meant by manufacture's settings is what they said in the manual, in normal mode: -2 at bottom, 0 at mid and +7 at full....in stunt mode: -7 at bottom, 0 at mid and +7 at full. I used my pith gauge to set all of these points......so the only thing left i have to do before i can fly it is set the throttle curve.
ill check out those vids now, thanks.
