RE: hangar 9 super stick 60
those things run a bit tale heavy depending on the engine you are going to use,try to keep all of your radio equipment as far forward as you can.i finally had to mount my engine further out than recommended to balance mine i have had two of them and they both came out tale heavy.i used a os 91fx in my second one.i read if you make them a tale draggier that that helps the balance point also.
