Getting more power out
i will try a graupner prop. here is the thing though, i can't replace the carb. i have a pumped engine and the regulator is attatched to the carb. it is specifically designed to fit modified os carbs. also about the high stall speed thing, yes, i do land it with some throttle, but i have to bring the idle dangerously low on the ground to keep it from scooting off.there is a delicate balance there. wait until you are over the runway to cut throttle, and bring it down really low and do circles. i can't use a break because i have a tail dragger
