RCU Forums - View Single Post - idle up & normal mode etc...
Old 07-10-2008 | 09:00 AM
Skarn
Default RE: idle up & normal mode etc...
ORIGINAL: legine
If this is the best type of curve available 100-100-100 then why dont i just enter that into my transmitter??? seeing as any change in head speed is minimal???
I did use a pitch gauge, what i meant by manufacture's settings is what they said in the manual, in normal mode: -2 at bottom, 0 at mid and +7 at full....in stunt mode: -7 at bottom, 0 at mid and +7 at full. I used my pith gauge to set all of these points......so the only thing left i have to do before i can fly it is set the throttle curve.
ill check out those vids now, thanks.
You can and should absolutely enter that into your radio for idle 1 if that's the curve you want. It's preference too....like I said, I run a V curve of (100, 95, 90, 95, 100) but am thinking about just running straight 100 since my curve is so close anyway and why not get that extra bit of power.
Ok, I see what you are saying now.....you did great in setting your pitch curves. A lot of new folk simply want to plug in numbers that someone else is using, but that doesn't work as I'm sure you now know.
Good luck bro!
Skarn
