Shutting down the engine
If you are supposed to set your throttle control on the radio so the engine idles when all the way down, how are you supposed to stop the engine at the end of a flight, but using the trim?
If so, it seems like you would always be chasing the low throttle setting. Is there another way to shut down an engine using the other controls on the radio, or with another device? Thanks.
