RE: CX2 swashplate sliding down-help
If you use the aluminum swashplate, watch out for bearing stiffness. Mine was stiff enough that it moved the servos when actuated and stalled out the lower blade. I loosened it up quite a bit, but am considering going back to the original plastic one.
