RCU Forums - View Single Post - Texas Hurricane
Thread: Texas Hurricane
Old 05-14-2003 | 10:09 AM
AJT
Default Texas Hurricane
STEVEN,
I used the the CA hinges that came with the HURRICANE kit. So far no problems I have not seen any bad threads on the stock hinges! However I always check the plane after every flight. As far as the stabilizer is concerned I think most people elect to glue. However I went the removable route. reason being I can take the plane with me on vacation. Gotta make room for the girlfriend and luggage thing! On that subject I installed blind nuts under the stab tongue support. I didn't feel comfortable with using wood screws as per plans, Also where the flying wires attach to the bottom of the aircraft I epoxied two nylon inserts (yellow ni-rod from throttle) for my wood screws to thread into. This makes for a very strong attachment, no slop or movement what so ever! I have removed the stab at least a dozen times for transport, and saw NO ill effects, Or have had any flight trim changes because of disassembly or assembly. Works for me!
I would only make one suggestion reinforce the firewall!! Mine came loose on the 7th flight, 3.2 Gasser. Other than that I have to tell you, THIS IS BY FAR MY FAVORITE AIRPLANE. If I were to crash it, I would buy another one immediately. Just a wonderful airplane. Your gonna love It!! Good Luck.
AJT
