RCU Forums - View Single Post - mode one or mode two
Old 07-10-2008 | 03:32 PM
Bill Fleming's Avatar
Bill Fleming
My Feedback: (35)
Default RE: mode one or mode two
There are three mode that two control stick can be arranged (I,II,III). Mode ll is step up so when the right stick is pushed forward/reverse, one got down/up elevator. Pushing left/right on the same right stick gave left/right aileron, very similar to a full sized airplane. The left stick gave throttle when pushed forward/back and rudder was controlled by push left/right. At one time there were transmitters that had one stick with a big twist knob on the end of the stick. This transmitters was also step up so when the stick was pushed forward/reverse, one got down/up elevator. Left/right stick gave left/right aileron. Twisting the big knob on the end of the stick gave rudder. It kinda went away because nobody liked it. Mode I was preferred by Pattern fliers because they felt a more precise control was possible by "spilting the sticks." Putting the throttle on the right with the ailerons and the elevator on the left with the rudder. Imagine a very long slooooow roll, the throttle is all the way forward and the right stick is pushed left (or right). At that time , there is no interaction between the ailerons and any other function because the throttle is all ready pushed all the way forward. This input is "locked in" and remains constant. As the plane rolls, rudder can very precisely be added and upon entering and exiting the inverted phase of the roll, the elevator can hold up the nose, then back to the rudder and exit the manuver. Think about it. The right stick is nailed down and you simply follow the roll action with the left stick by making 270 degree circle (right rudder, blend in down elevator while blending out the right rudder then the reverse). BTW There is a mode III, but in 50 years of modelling, I've never seen it used. Wow! I didn mean to take so much time to answer your question.
I'm not going to proof this because I might find something else to add. Nuff said!
Happy flying, Bill
