RE: Angel S EVO Build Thread
Russ
I would not discount anything that SebArt recommend, the plane is so good I am sure there recommendations are as well, the only reason I am using an AXI is that I had it already, so was the obvious choice for me.
If you go the AXI route the back mount will need a small amount of file work to line up the holes for the installed T nuts in the bulkhead, mine is now about four years old and has seen out, I think its 12 LiPo packs without a hiccup.
Mike
