RE: Receivers for electric models
Oistein that is great info! What futaba module are you using? Do you have any photos or references explaining how the modification is done?
I have heard that the Futaba 2,4 Ghz receivers are using a lower then normal signal level to the servos. Have you had any problems using JR servos with the futaba receiver? Or perhaps you are using futaba servos?
David
