ORIGINAL: LordSirOb
The noise police nabbed me, and I would like to go with a header/canister setup on my B60. Is anyone using a KS 86 on their B60? Or the MTW TD75? As I understand it, a DA 50 header works, but you need to do some filing on the bolt holes. Is that correct?
Thanks in advance.
Ken
I ran a KS 1060 on mine for a bit (6 flights before a system failure and bent the pipe) Throttle response was amazing.. I didn't get time to play with header length though to see what kind of power I can get out of it. I have heard numbers around 7550 with a Mejzlik 23x8 on a ES comp pipe (the older 50cc one).
Yes any DA header will work.. just have to slightly enlarge the holes.
