RE: Extra plane suggestions.
Looks to be about 1.5oz of lead from what I can see in the photo. If so that isn't all that much and you should be able to move the gear around to get it to CG without the lead.
If not don't sweat it. When you change the plane over to A tail dragger that will probably remove all the lead.
As Dave said, get that engine tuned and running well!!
