RCU Forums - View Single Post - Can a Heli engine be modified for planes?
Old 07-11-2008 | 05:51 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Can a Heli engine be modified for planes?
Actually the crank shafts are a bit shorter. If you can safely get a thrust washer, prop, washer and prop nut on there you're fine. Other than that it will work pretty much the same.
