RCU Forums - View Single Post - Help with Bi plane, ailerons not working right
Old 07-11-2008 | 07:53 PM
iron eagel's Avatar
iron eagel
Default RE: Help with Bi plane, ailerons not working right
Something in the setup is binding and I recall that being an issue with an ultimate someone else had he had one set of horns that were longer and it caused the ailerons to bind when the top surfaces were attached. Or it could be a weak servo test the servo under load.
