RCU Forums - View Single Post - TH KAOS MOD'S
Old 07-12-2008 | 01:23 AM
alcarafa's Avatar
alcarafa
Default RE: TH KAOS MOD'S
Hi guys I have finished the mod's on my TH KAOS, set up ended with SPEKTRUM DX7 & DS821 Digital servos, 6 v 2500 mah battery, striped and covered again with transparent red ultracote , silver and white monokote, Os 46 FX with MACS pipe and APC 10 / 6 propeller. Also changed all the hardware supplied with the plane except engine mount.
This lady flies fffffaaaasssssssssttttttttttttttt !!!!! specially at sea level where I live.
I followed set up for servos, ailerons, rudder and elevator from another post here in the forum, and it really is smooth as silk.
HERE ARE THE PICTURES OF THE MODS FROM MY TOWER KAOS, YOU CAN NOTICE I UPGRADED THE HARDWARE, COVERING, CHANGED THE TAIL ON BOTTOM, THE NEON GREEN ON BOTOM OF WINGS IS A GOOD WAY TO SEE HOW THE PLANE IS FLYING WHEN PLANE IS ROLLING.
Hope you like it
Rafa
ID:	988920   Click image for larger version
ID:	988921   Click image for larger version
ID:	988922   Click image for larger version
ID:	988923   Click image for larger version
ID:	988924   Click image for larger version
ID:	988925   Click image for larger version
ID:	988926   Click image for larger version
ID:	988928   Click image for larger version
