Hinge Alignment Problem
I installed CA hinges on the elevator of my LT-40. The elevator seems to "snap" between the up and down position, that is there is not a smooth transition as the elevator passes over center. The more I work the hinge, the smoother it gets, but still not perfectly smooth. This also appears to create a small flex in the stabilizer at the same time.
Did I get the hinges misaligned or could this result from a warped elevator or both? And should I pull it apart and try to fix it or will this be ok in flight? I dread trying to pull apart CA hinges.
