RCU Forums - View Single Post - PULL/PULL SETUP
Old 07-12-2008 | 11:02 PM
Campgems
Default RE: PULL/PULL SETUP
Pull Pull setup is quite simple, but it requires a bit of geometry to make it work well. The basic idea is to translate the movement of one end of the servo arm to an equal movement of the rudder or elevator horn. This requires a couple things. First, the center of the servo arm to the attachment point has to be the same as the hinge line to horn attachment point. 1/4 " of movement on the servo arm attachment point has to equal 1/4" of movement on the horn. If you don't have this setup correct, one side of the cable is going to go slack. This results in fluttering some times.
The second thing is not to build any Ackermond (spelling??) into the linkage. This requires that the center of rotation of the servo and it attachment points or both sides be on a single line, and the same goes for the control surface. Right horn attachment point through hinge line to the Left hor attachmen are all on one line. This ensures that the control surface exactly follows the servo movement and that both cables remain tight throughout the move.
I'm currently fine tuning a Ruperts Dad that I set up with a pull-pull rudder. I made the mistake of putting the attachment points of the horns behind the hinge line of the rudder. The Pull side is tight but the other side is slack. In a netural position, both cables are tight, but as soon as the rudder starts to move one side goes slack. This is not good.
This is a basic setup problem that a rooky, like me, made. All throws have to be equal and all have to be on the same reference line. Everything has to be tight what ever position the surface is in.
Don
