RE: FARIDAY SCREEN
Hi Rob Tried just about everything new boards different ariels different motors . still stays about the same must be the schurzen blocking the signal or R.F. from motors which cant dispate because of schurzen it looks like will have to change to 2,4ghz when Ifit the dbu /dbc wanted to keep it 27mhz am but needs must dont have any problems with any other tank ,think ill fit a recoil unit at same time .Just thought Iwould ask the Question in case im missing some thing need one of them electomagians to say if it would cut R.F.when you think about it there are 7 motors inside the panzer3. 2 drive motors 1cooling fan 1 smoke unit 1 turret turn 1 elevation motor 1 gun motor . plus radio gear 2 batteries now ive got to find room for the dbu/dbc units and wiring also if another reciever .its going to look like the inside of the wifes handbag .
best regards pete
P.s looks like one of the batteries is coming out to make room .
