RCU Forums - View Single Post - Help wire my first electric
Old 07-13-2008 | 10:04 PM
  #50
sparky925
Default RE: Help wire my first electric
we cloud skipper you are basically correct.
increase in voltage means increase in rpm, the increase in heat. The motor needs to allow the heat to dissapate by spinning more RMP. If the prop will not let the motor unload then the heat created just stays in the motor and melts the varnish off the windings and the motor shorts out.
