RE: FLy Eagle Jet Models
Morning all Got a couple of questions about the f16 for you all i need help.
1. The elevators are not balanced so when you have no servo power on they drop at the rear but when they are powered i get permanent chatter from the servos does everyone have this problem if not how did you solve it and if you do is there a problem with power drain. Was worried about balancing them as i don't need to be adding anymore weight at the back or i will have to add it at the front too. I have a powerbox with two lipo cells so the power drain would i guess be minimal.
2. I have not taken my landing legs apart yet but with the weight of the plane the main 2 legs springs are not strong enough to push the plane back up. I know some of you put another spring inside. The question is where did you get the spring and how do you take the gear apart.
Thanks in advance for the help
Rob.
