RE: 400T AND/OR 400BL
I would not advise using the 480 without the gearbox on the pitts, you would have to use a small prop and you need a larger prop for the pitts
you can just use an outrunner in the place of the gearbox but you need a lower KV motor that will allow you to be able to spin a big enough prop for the plane
