ORIGINAL: BaldEagel
Finnaly got the Plett up and running on the Anyliser, temp 1 is the batteries and temp 2 is the ESC supprisingly because of the wind from the prop the temps go down during use in a ground run, I doubt if this will happen in the air, the wave form for the ESC is from the anyliser hence the jump in amps every 10th cell approximatly on the spread sheet, prop used was a 22x10 RASA's folding on the in spinner Plettenberg, all looks very promising with 56amps and 6200rpm should fly well.
Mike
Well theres a thing can't import Excell spread sheets.
Well it flew at the week end in company with a couple of 3M 150cc composite planes, whilst not as fast as they where it flew very well, also on site was another Composite ARF 2.1M with a DA50, in short mine did not have the vertical of these planes, obviously not pulling enough amps with the 22 x 10 will need to change this, the C of G was too far forward and the coupling to the belly will need to be dialed out on the Tx, this was being done on the other 2.1 whilst at the site.
All in all very happy with this conversion just need to do a few adjustements to get more amps out of the motor and do some dialing in.
Mike
