RCU Forums - View Single Post - Which 20% Nitro fuel to use?
Old 07-24-2003 | 04:52 AM
BUGGIES_R_US's Avatar
BUGGIES_R_US
Default Which 20% Nitro fuel to use?
Remember that Blue thunder is only 10% oil!!
BT is specially formulated with .21s in mind. I wouldnt run them in .12s.
Remember that the surface area of the sidewalls of a .21 isnt much bigger than a .12 but the volume IS! (theyre not linear).
more volume= more fuel mixture= more oil.
So with a .12, your effective "oiling rate", if you will, with BT is actually a bit lower than with a .21.
So for a .12, BT is a little too dry!!
Ram
