RE: Fuel line problem
tke the remote needle valve off and put it in a bowl of water (keep fuel lines attached and blow through them), if there is a leak in the RNV it should bubble in the water, strip down the NVA (make note of the settings) and check all the seals and o-rings, you may want to try replacing the fuel tubes aswell, even a tiny pin ***** can cause problems
