RCU Forums - View Single Post - JR Charging Jack installation
Old 05-14-2003 | 06:33 PM
Dzlstunter
Default JR Charging Jack installation
I have my first JR radio, and installed the charging jack on my fuse the only way I could see it being attached. But when I try to plug in the charger, the charger plug pushes the battery lead backwards (past the snapping retainer) and into the fuse. How have I messed this up? The snap retainer does work, and I have checked to make sure I am inserting the charger lead in with the correct orientation. But the snapper(?) lets go because the two leads do not seem to match up inside the fuse mounted jack. They work fine if I'm not using the jack (plugging them together directly). Thanx for any help, Dzl
