ORIGINAL: zbird68
I installed a satio 100 in my seagull harrier inverted. when I fill up the tank it fills up my carburator with fuel,and floods it. Do these engines run ok inverted, or should I try to mount it right side up?
Even better, buy a Cline fuel regulator, and you can mount the tank on a pedastal above the cockpit. It will not allow the engine to flood, and is very easy to set up and use.
Bill, AMA 4720
WACO Brotherhood #1
