RCU Forums - View Single Post - HPI's Tuner Kit
Old 07-14-2008 | 06:32 PM
eXunforgiven's Avatar
eXunforgiven
Default RE: HPI's Tuner Kit
ORIGINAL: Doonagoowin
Have you tried with that exhaust? Does it really work without major effects?
I think that something will be effected by that.
I ran it yesterday and it ran fine for about 5 minutes, then the straw I used to connect the muffler melted!
ORIGINAL: sloppyG
I would imagine that exhaust setup would cause some problems with running the engine
but the work looks top notch
It was actually running fine, no restriction problems, I had melting problems!
ORIGINAL: magnat
doesn't seem to rev as freely ??? adds a little tone to the exhaust as well.. Nice work..
I didnt notice much difference in the reving to tell you the truth.
ORIGINAL: Stunt4life
That is so unbelieveably sexy I cant even begin to tell you.
How far did that set you back if you dont mind my asking?
and i doubt it woudl afftect anything, its just a large dump tube...
That tuner kit is only $12, pretty cheap if you ask me.
It makes the air travel longer and further, but I dunno what the effects of that would be.
Why does it seem like when you let off the throttle, the wheels stop spinning immediately?
The wheels are way to light to gain any kind of momentum stong enough to keep them spinning, specially with all AWD. That along with the servo slightly engaging the break on its way back. If it was on the ground running it would be a different story.
