RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 07-14-2008 | 08:48 PM
  #6852
theradioflyer's Avatar
theradioflyer
Default RE: Wheeeeeeee.......... Blade CP!
Tim, your not alone on losing these small parts. I think Dave did a tip of the day on this, I can't remember. You can put a towel down and maybe work over a tray. My problem is not realizing that there's a loose part until it falls out and goes bouncing away. I can't tell you the countless hours I've spent crawling around my basement floor looking for screws, washers, bearings, and such[X(]
Jer, good to hear from you! Sounds like you have the Stryker under your belt. That's a steep learning curve so any other planks, ( with the exception of warbirds), so be a walk in the park. It's kind of like learning to fly on the Blade and then getting a bigger belt driven chopper
Rick, I hope it get's better, if not head in for another shot and maybe a chiropractor to fix the nerve. Prayers still going out for you
God Bless Ya,
Jay
