RCU Forums - View Single Post - CC Sidewinder Programming - No Reverse
Old 07-14-2008 | 09:47 PM
cub2000
My Feedback: (14)
Default CC Sidewinder Programming - No Reverse
I've recently bought a CC Sidewinder for my crawler. I'm using it with an external CC BEC to handle the servos for my brushed motor 55T
To program it, I did the following:
. Pulled the trigger on maximum (100 EPA) throttle and turned on the ESC, the light turned flashing green.
. When the light turned flashing red, I pushed the trigger forward at brake position (100 EPA)
. When flashing yellow, I relieved it to neutral, then it turned solid yellow.
The crawler works fine with moving forward and steering, but there is NO reverse.
What am I doing wrong? I'm using a Futaba 3PM 2.4ghz radio system.
Thanks in advance.
