RCU Forums - View Single Post - Prince 25" Mono
Old 07-14-2008 | 11:49 PM
FHHOBBIES
Default RE: Prince 25" Mono
Well I went out tonight for a quick rip and after about 1 min it started going crazy a bit so I brought her back, when I opened the hatch a bit of smoke came out, I thought it was the motor because it was so hot I could not touch it but my ESC wrap is also melted and does not seem to be working perfect anymore. No water got in anywhere. I must have been pulling lots of amps because my pack was even warm after my 1 min or less run, I will try and figure out the problem. There seems to be a tad bit of slop in the drive, I wonder is that is causing the vibes and drag, the drive dog can't be helping either. I will play with boat #2 to see if it has the same problems.
