RCU Forums - View Single Post - Throttle Exponential
Old 07-15-2008 | 01:12 PM
chuck l
My Feedback: (17)
Default RE: Throttle Exponential
ORIGINAL: krayzc-RCU
chuck,
I wanted to make sure you could not play with header length. Also are you running a throttle mix to make the rpm linear?
As mentioned in the original post, the issue is the DX7 radio doesn't have a throttle mix in the airplane mode. I guess I called it throttle expo, which confused the issue. So if throttle mix will help with hovering, I'll have to try the heli mode.
