RE: Throttle Exponential
i found using the travel adjust can help a bit also as you can change travel for the low and high end of stick movement.
cant recall quite what i did but i think the low travel adjust was dropped to about 40%, so up to half way on the throttle stick the servo would only have 40% of its original movement
