ORIGINAL: RC-3D
Tom,
On The 1100mah A123 does it come with dean connector and cellpro charger connector? How much it weight each?
Pathapol
I only have packs in stock with a standard servo connector, but I can order them in any configuration. My original idea was to use them for ignition, but they will work well on receiver applications also. They weigh 3 oz.
My reasoning is this. If you have an application that pulls more than 4 or 5 amps from a battery pack you probably ought to have the 2300mah packs. But these smaller packs (1100mah) will work fine in a small plane with dual battery packs and dual switches. It's a great lightweight redundant system for up to a 35% plane where each pack will only be required to supply 1-2 amps steady and maybe 5 amps in a burst. This is well within the capacity of standard servo connectors and is simple and cheap.
It's the perfect answer for 50cc size planes where guys want redundant supplies.
TF
