RCU Forums - View Single Post - Need suggestions for tail dragger conversion
Old 07-16-2008 | 12:06 AM
Tissan
Default RE: Need suggestions for tail dragger conversion
first thing i would do is cut off the horn after the hole you are using!
you know maybe it can fly without a tail wheel at all only with a skid.....
or a wheel without linkage to the rudder at all, just a free wheel, if you give enough throttle it pulls the tail up anyway....
or you can over engineer something that will change the CG and then you have alot more issues to deal with.
Alex
