RCU Forums - View Single Post - Welcome Weatronic's
Old 07-16-2008 | 07:49 AM
ddennison
My Feedback: (15)
Default RE: Welcome Weatronic's
I am just getting started with my Weatronic and am looking fro some help with a few questions. Any help is appreciated:
1) When saving the the set-up in the PC I understand you MUSt be attached to the reciever by the USB?
Can I program the initial configuration without being attached to the receiver?
2) When saving the set-up, how do you switch between models and make sure the receiver is loaded with the correct model? Is this automatic when you "save"?
3) Does the save feature save the program on the PC AND within the receiver? (My understanding is that the SD card is not for programming, just updating firmware and downloading iin flight data)??
4) When do you synch? I will have only one servo per surface but willl have two servos for rudder, elevator, flap (F22). Can or should I synch those so thay have the same travel?
Thanks in advance!
Dave Dennison
