RCU Forums - View Single Post - Thrust Data?
Thread: Thrust Data?
Old 07-16-2008 | 01:06 PM
indoorff's Avatar
indoorff
Default RE: Thrust Data?
Thanks for the advice guys. Lou - do you have a particular spreadsheet link you can recommend? I will try a few different props and measure RPM and make some more approximations, but sounds like in the neighborhood of ~2lbs is what I can expect. Will have to weigh the engine, and see how likely it will be to make a model with a thrust to weight ratio greater than 1:1 (perhaps not too likely).
Chris
