RE: U-can-do falling right from hover problem.
You need to check the right thrust. try flying direct away from you and then pull vertical and keep climbing without touching rudder and see what the plane does. If it pulls left, you need more right thrust in the engine. If it pulls right, then you need less. Once you get this adjusted, then re-evaluate how it reacts in a hover. An improperly balanced (total balance) plane will be a handful to 3D and especially hover.
