RE: Does Spektrum offer a 2.4Ghz Module solution for a Futaba 9C?
I think changing the 9C antenna out is more work than simply unscrewing it, if I remember correctly. In any case you could just get a 2.2db antenna and just screw it to the connection on the module. I did that with my JR XP9303 as I thought the wire from the module was hokey and an accident waiting to happen. Haven't had any problems with that setup. Ideally it would have been better if Spektrum had made the antenna connection near the top of the module and pointing up so the antenna could be screwed to it and sit between the handle and the transmitter, similar to what XPS did.
