RCU Forums - View Single Post - Perry Pump ???
Thread: Perry Pump ???
Old 03-17-2002 | 12:31 PM
RControlFreak
Default Perry
I use a Perry pump and a Perry carb on a OS160FX. THe tank is about 12" away from the carb. It works PERFECTLY. The attitude of the plane doesn't affect the rpm at idle or full throttle.
I was originaly going to use the pump with the stock carb but the Perry pump carb has a reduced venturi effect and won't run rich in the mid-range using a pump.
Ken
