It's best to run the right size plug as the combustion chamber of your engine is a very important piece to the puzzle and you want it to work right as it was designed to. With the right size plug the base of the plug should be even with the head button/combustion chamber. I as well have used the 2 washer trick with long plugs on a short plug application. Works well when in a pinch
