RCU Forums - View Single Post - balsa snapping????
Old 07-17-2008 | 11:09 AM
Jim Thomerson
Default RE: balsa snapping????
My only experience is with molding a small fuselage and several leading edges out of laminated 1/32 sheet. I used plain water with a little spritz of Simple Green. The sheets were limp in seconds. The problem is with getting the balsa sufficiently wet. Ammonia is not needed. Ammonia is used on other hardwoods to soften the subrin and lignin compounds largely absent in balsa.
