RE: Plane #3 on the bench
i like ca hinges they are fast and easy,i also like pinned hinges you can use tooth picks to pin them in place also.use a tooth pick and smear Vaseline on the hinged areas on pinned hinges to keep the epoxy from causing them to glue together.when the epoxy cures you can use a #11 blade and pick the excess away easily.
