U-CAN-DO 3D, what has your experience been?
Thanks for the info Wayne & trailingedge!
I already replaced all the pushrods with 4-40 stuff, and I'm probably going to make a new tail wheel assembly with springs. Not that I'm scared of braking the one that came with the kit, but I want to take some of the abuse off of my new (and expensive...for me anyway) digital servos I'm using. I'm thinking of adding a little bit of epoxy to the inner firewall, too. Maybe some of it will wick in. I also plan on putting a couple more little reinforcements in the landing gear mounting area. But that should be it.
trailingedge...when you realigned your gas tank, did you have to go in and hog out the formers to accept your new location?
...If I'm going to be flying a horrible plane, I want it to be the BEST horrible plane I can fly!
Thanks again for the help!
Mark
