RCU Forums - View Single Post - U-CAN-DO 3D, what has your experience been?
Old 05-28-2003 | 08:53 PM
  #54
visioneer_one
My Feedback: (506)
Default My experience...
Was short.
YS .91AC & Slimline Pitts muffler. Stock fuel tank on the CG. Shifted the throttle servo to the rear end of the radio compartment. Five coreless FMA servos used - three in the tail, with the metal-geared one on the rudder. Sullivan tailwheel instead of the stock assembly. 2-56 CF pushrods and Rocket City ball links on all surfaces.
My kit made its long trip and arrived with no damage to the wing. The covering was a bit wrinkly in places, but nothing that a blast from the trusty heat couldn't fix.
Stayed up all night Saturday finishing it. Hit the sack & caught some Z's @ 7AM, then to the field forthwith.
Fueled up, fired up. The engine ran *pefectly* on my usual YS mix of 30% nitro 20% oil.
Wups! Spoilerons are reversed - up is down, down is up. Shut down, pulled the wing off, swapped the aileron servo connectors, reinstalled the wing.
Fired up and took off.
Total flight time? 9 seconds.
Oh.
Reversed ailerons.
(With a 10X and flaperons you have to make sure that (A) the L and R aileron servos are plugged into the correct rx port, and (B) that they are wiggling in the appropriate direction.
The new kit is on order.
