RE: First airboat build
I usually come up with something that will work and I think this will do the job. I didn't use duck tape, but instead, a couple of wire ties on the handle through holes to the underside of the plywood and two rubber bands around the rig to finish securing the TX to the plywood. While the cam is flat, the TX is slightly angled upward for a comfortable position. The viewing screen is where I can keep an eye on it to make sure it's level. I'll use a neck strap to hold the rig steady. It's easliy removable to put on my TX for my sailboat to get videos of that as well. I'll try this afternoon if the rain holds off as the winds will be better for sailing.
