RE: Jett Muffler - Performance Decrease With Deflector.
No effect on power output or performance.
You want a tube that has an inside diameter that slips over the tail piece on the muffler. Then secure it with a thin zip tie. Try and keep the length to a minimum.... under 2.5" is a good target.
Typically the 40-90 size deflectors from Great Planes and Dubro work ok. You would want to avoid anything much longer than that.
