RCU Forums - View Single Post - Need help with epoxy decision.....
Old 05-15-2003 | 08:58 AM
tempus
Default Need help with epoxy decision.....
When preparing to glue the wing halves together it is important to dry fit them first to ensure they will go together when start applying the glue. Also important is some sort of jig to hold the wing while the glue cures especially if you use the 30 minute or longer. And finally mix a large enough batch to complete the job as you don't want to race against the clock to mix a second batch while the first is curing!
