RCU Forums - View Single Post - Top Flite B-25 - Wingspan Models Add-ons Build Thread
Old 07-18-2008 | 04:32 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Top Flite B-25 - Wingspan Models Add-ons Build Thread
To continue on, we now need to cut the formers and stringers. My razor saw is pretty thin (If you don’t have a Zona razor saw definitely get one. They are worth every penny) and I could get it in to the cut marks made with the hobby knife. But if your saw isn’t this thin them you will want to pull up the covering around the area so that the saw doesn’t rip it.
Since the location of the stringers and formers are marked it’s pretty easy to cut down through the with a razor saw. After cutting them all I went to pull the cut section away and found that it was still attached. After looking through the holes in the fuselage I found that there was still parts of the formers left that I could not reach with the razor saw, there was a small section in the middle of the fuselage still securing the bottom in place. In picture #3 you can see that I have a small blade from a hole saw that I use to cut areas like this. With this blade I was able to work down inside the fuselage and cut the remaining portions of the formers. With these cut the bottom area comes away freely. When removing the cut out section mark it so that we can keep track of with end is forward.
Use a razor saw to cut away the two cross sections of the formers.
Pictures
1. Use a razor saw to cut through the stringers.
2. Use a razor saw to cut through the formers.
3. A hole saw blade can be used to cut away portions not accessible by the razor saw.
4. Use the blade to completely cut away the section.
5. Remove the cut away section.
6. Remove the cut away section.
7. Remove the cut away section.
8. Remove the cut away section.
9. Mark the front portion of the cut away section.
10. Two cross braces remain.
11. Use a razor saw to cut away the two cross braces.
12. Bomb bay section opened up.
Until next time
Ken
ID:	993112   Click image for larger version
ID:	993113   Click image for larger version
ID:	993114   Click image for larger version
ID:	993115   Click image for larger version
ID:	993116   Click image for larger version
ID:	993117   Click image for larger version
ID:	993118   Click image for larger version
ID:	993120   Click image for larger version
ID:	993121   Click image for larger version
ID:	993122   Click image for larger version
