Help getting started with a 4 channel transmitter?
I've never used a 4 channel transmitter before only 3 channel so it's a bit daunting. As is, my Pitts bipe came like this: Throtte and rudder on the left stick, channels 2 and 4 respectively. The right stick is set up elevator and aileron, channels 3 and 1 respectively. I'm trying to switch the ailerons and rudders channels so both up and down and left and right movements are on the right stick. The manual, what I can understand says this can be done but when I switch the two things start going haywire. My question is how does everyone fly? Do you guys have the ailerons and throttle on the same stick? I would think this is harder to fly. It's going to have to take some getting used to I think on my part if that's the way it is. Also on my transmitter, there are 4 switches for the channels all saying up for reverse and down for normal. What do these do? My manual is mostly in chinese and it doesn't cover these switches.
